Shiverman45
May 03, 2023Aspirant
R7450 how do I access and change the firewall
My wife recently started working for a company based out of Germany and they sent her a laptop with their specific software installed on it. Our router won't allow the software access and the company...
Shiverman45
My modem and router are all in one. I'm not sure how to do either of those things you mentioned.
May 03, 2023Guru - Experienced User
The R7450 isn't a modem/router. Its a router-only device.
So its connected to something,what is that?
The manual would be a good place to start with what I recommended.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
