Sobendo
Jul 21, 2023Aspirant
R7450 Loosing connection to internet on WIFI 2.6 or 5G
Has anyone had issues with loosing internet connection on wireless use? I connected hardwire RJ45 and works fine and never looses connection.
Jul 21, 2023Guru - Experienced User
What model NH router do you have? R####?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON
- SobendoJul 22, 2023AspirantThank you
Model- R7450
Firmware-V1.2.0.92
ISP- windstream Kinetic fiber
ISP modem -Calix Giga point 803G
I preformed a router reset and all recommend settings. WIFI is set default except I changed channels to 3
I will do some test later today and report back. - SobendoJul 23, 2023AspirantFactory reset seemed to my issue. Thank you
- michaelkenwardJul 23, 2023Guru - Experienced User
Sobendo wrote:
Factory reset seemed to my issue.Always worth trying.
Make life easier for yourself if you have to do it again by following these instructions:
Next time it happens you won't t have to reconfigure everything.
