Sobendo
Jul 21, 2023Aspirant
R7450 Loosing connection to internet on WIFI 2.6 or 5G
Has anyone had issues with loosing internet connection on wireless use? I connected hardwire RJ45 and works fine and never looses connection.
michaelkenward
Jul 23, 2023Guru - Experienced User
On which wifi clients? All of them? Only some?
What do the wifi LEDs look like when this happens?
- SobendoJul 23, 2023AspirantThank you but. Factory reset seems to have worked
- michaelkenwardJul 27, 2023Guru - Experienced User
Sobendo wrote:
Thank you but. Factory reset seems to have workedThat's good. An earlier message from you suggested that a factory reset did not fix the problem.
