Sobendo
Jul 21, 2023Aspirant
R7450 Loosing connection to internet on WIFI 2.6 or 5G
Has anyone had issues with loosing internet connection on wireless use? I connected hardwire RJ45 and works fine and never looses connection.
michaelkenward
Jul 23, 2023Guru - Experienced User
On which wifi clients? All of them? Only some?
What do the wifi LEDs look like when this happens?
Sobendo
Jul 23, 2023Aspirant
Thank you but. Factory reset seems to have worked
- michaelkenwardJul 27, 2023Guru - Experienced User
Sobendo wrote:
Thank you but. Factory reset seems to have workedThat's good. An earlier message from you suggested that a factory reset did not fix the problem.
