Sobendo
Jul 21, 2023Aspirant
R7450 Loosing connection to internet on WIFI 2.6 or 5G
Has anyone had issues with loosing internet connection on wireless use? I connected hardwire RJ45 and works fine and never looses connection.
Sobendo
Jul 23, 2023Aspirant
Factory reset seemed to my issue. Thank you
michaelkenward
Jul 23, 2023Guru - Experienced User
Always worth trying.
Make life easier for yourself if you have to do it again by following these instructions:
Next time it happens you won't t have to reconfigure everything.
