Ajdhn2
Apr 13, 2021Aspirant
R7450 NIGHTHAWK Router Internet issues
Hello, I'm currently experiencing internet issues with my R7450 nighthawk router. My home internet speed is roughly 60Mbps and usually has 6 to 8 devices connected to it. Not all of these devices wil...
Ajdhn2
Currently I use a modem that is provided by CenturyLink internet provider. As far as I know my r7450 is up to date on the newest firmware. I believe I have qos setup. I have my gaming pc set to the highest priority and all the other devices in my home set to the normal.
Ajdhn2
The qos I setup though didnt seem to work. My wired gaming pc was receiving less internet speed than the wireless laptops. I checked this by doing speed test on the devices and also seen this in my in game ping.
- antinodeApr 13, 2021Guru
> provider. [...]Did anyone ask where you got it?
An actual maker and model number would be more helpful than where you
got it. Is it actually "a modem", or is it a modem+router?If your (unspecified) "a modem" is actually a modem+router, then why
are you using an R7450 with it? Do you have client devices connected
directly to your (unspecified) "a modem"?
> The qos I setup though didnt seem to work. [...]Do you think that anyone here can see what you did? "seem"?
- Ajdhn2Apr 13, 2021AspirantThe model number for my modem is C1100z. Zyxel is probably the maker of this modem. The modem does have routing capabilities but I currently have that disabled and have the r7450 nighthawk router doing that job. I'm not sure what you mean by client devices?
> [...] I currently have that disabled [...]
"disabled" how, exactly? Does the WAN/Internet interface of the
R7450 have an external/public IP address?> [...] I'm not sure what you mean by client devices?
Computers, and so on.
