Fulmerb's avatar
Fulmerb
Follower
Jun 19, 2021
R7450 only shows red power light
I’ve never had a problem with this or any router for more than an hour. After we had a storm, and the power went off, the modem restarted, but the router didn’t. Instead it shows the power light as a solid red light. I’ve tried resetting the router, and power cycling it, but nothing has worked. I also switched my Ethernet cable, and that also didn’t work.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may of had a power surge and the router got hit I suggest contacting support.
    DarrenM
