tecee21
Sep 27, 2021Aspirant
R7450 Power light blinking after
I was trying to update the firmware on my router and my ISP signal dropped in the middle of it. Now I have that blinking white power light. I have tried the TFTP, but I do not get the pop up box that ...
Sep 28, 2021Guru - Experienced User
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
tecee21
Oct 06, 2021Aspirant
plemans sorry that it took me so long to respond. None of the tftp stuff has work, could you give me some insight as to how to do the nmrpflash. Thanks in advance for your help.
- plemansOct 06, 2021Guru - Experienced User
it has instructions on it that walk you through pretty much the whole thing as well as troubleshooting. where are you failing in the process?
