tecee21
Sep 27, 2021Aspirant
R7450 Power light blinking after
I was trying to update the firmware on my router and my ISP signal dropped in the middle of it. Now I have that blinking white power light. I have tried the TFTP, but I do not get the pop up box that ...
tecee21
Oct 06, 2021Aspirant
plemans sorry that it took me so long to respond. None of the tftp stuff has work, could you give me some insight as to how to do the nmrpflash. Thanks in advance for your help.
Oct 06, 2021Guru - Experienced User
it has instructions on it that walk you through pretty much the whole thing as well as troubleshooting. where are you failing in the process?
- tecee21Oct 11, 2021Aspirant
Don't know why the photo didn't come through, I attached it to this message.
- plemansOct 12, 2021Guru - Experienced User
I rarely need to use nmrpflash but it doesn't look like all your commands are written correctly.
did you scroll down and go through the "using nmrpflash" on the site? did you change the name of your firmware as well?
You need to follow things to the letter on there.
- tecee21Oct 14, 2021Aspirant
plemans is there a way that I can check to see if my laptop is communicating with my router? Every time I try the tftp route this is what I get:
Microsoft Windows [Version 10.0.19042.746]
(c) 2020 Microsoft Corporation. All rights reserved.C:\Users\tcartwright>cd desktop
C:\Users\tcartwright\Desktop>tftp -i 192.168.1.10 put R7450_V1.2.0.88_1.0.1.img
tftp: can't read from local file 'R7450_V1.2.0.88_1.0.1.img'C:\Users\tcartwright\Desktop>tftp -i 192.168.1.10 put R7450_V1.2.0.88_1.0.1
tftp: can't read from local file 'R7450_V1.2.0.88_1.0.1'The tftp is activated on my laptop and I changed the Internet Protocol.
