Mopar70
Sep 25, 2024Follower
R7450 speedtest slower than modem @800+MBPS vs 360MBPS
I am running a CM1200 cable modem on a gig plan averaging 800+MBPS and the R7450 speed test is showing 300MBPS range. I have a CAT8 cable running between router and modem, traffic meter is disabled.
Sep 26, 2024Guru - Experienced User
Factory reset and reinstall (not from a backup)
During the install leave qos, access control, parental controls, and traffic monitoring all disabled.
then test with a hardwired device with the test hosted on the hardwired device (which device did you test with)
