jszar
May 02, 2017Aspirant
R7500 - No Internet on wifi network
R7500 Nighthawk X4 AC 2350 / Firmware v1.0.0.94 / Mostly Mac devices / Home use The LAN connection to my iMac USUALLY works, sometimes it does not though. The internet light on the router is blin...
- May 14, 2017
Hi jszar,
1. When no internet on wifi, does wired works?
2. Try setting DNS Address 4.2.2.2 or 8.8.8.8 under internet setup.
JamesGL
May 14, 2017NETGEAR Employee Retired
Hi jszar,
JamesGL
May 18, 2017NETGEAR Employee Retired
Hi jszar,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- JamesGLMay 25, 2017NETGEAR Employee Retired
Hi jszar,
Is the connection still stable?
- JamesGLMay 29, 2017NETGEAR Employee Retired
Hi jszar,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
