jszar's avatar
jszar
R7500 - No Internet on wifi network
R7500 Nighthawk X4 AC 2350 / Firmware v1.0.0.94 / Mostly Mac devices / Home use   The LAN connection to my iMac USUALLY works, sometimes it does not though. The internet light on the router is blin...
  • JamesGL's avatar
    May 14, 2017
    Hi jszar,
    1. When no internet on wifi, does wired works?
    2. Try setting DNS Address 4.2.2.2 or 8.8.8.8 under internet setup.
