justinl
Jul 08, 2017Guide
R7500 - Unable to edit Dynamic DNS settings
I am experiencing the same issue reported by several others at the closed thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7500-Dynamic-DNS-Issue/m-p/1057157 After I enter my ...
JamesGL
Jul 26, 2017NETGEAR Employee Retired
Hi justinl,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
