harvey18656's avatar
harvey18656
R7500 doesn't find my IP cam
Hi,
since yesterday I'm using a Nighthawk R7500 and I can connect all my devices. Only one doesn't connected, a DB-Power IP cam. While connected by wire I have setup the cam using DHCP server and setup the SSID and Password and all other thinks needed for Wifi. But I get no connection to the router.
Does anyone knows what I can do to get it connected ?
Thanks
 Harvey
  • I have found the problem. The 2,4 Ghz chanal was 12. I have changed it to a lower value (4) and now, the cam works.
  • Double check that you entered the correct SSID, password and security protocol (i.e. WPA2, WPA, WEP) on your camera.  Check the logs on the R7500 for any signs that the camera attempted to connect.
    • harvey18656's avatar
      harvey18656
      in the Cam setup I have searched for available networks and then I have selected my network and I have more than once checked the password and the security protocol. Everything is fine.
      For a short time, the connection LED on the Cam is on, but it allways turns off, what means, no connection. On the router I don't know how/where I can find logs :(
      • TheEther's avatar
        TheEther
        Guru
        The logs are located at Advanced > Administration > Logs.
