mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Trym
Nov 19, 2015Initiate
Having the same issue too on the latest firmware. Internet is dropping on the wifi all the time.
Sometimes it isn't even stable for 5 min after a reset of the router.
rmfpdx
Nov 19, 2015Aspirant
Life's too short to waste any more time on this nonsense. Nothing has made it better. Except that I have switched out to a new Apple Time Capsule Airport Extreme router and couldn't be happier. No more dropped wifi :)
- JamesGLNov 22, 2015NETGEAR Employee Retired
Hi All,
Please send me a PM with your contact info.
- CreakydoorNov 30, 2015Tutor
+1. Running 1.0.0.94 firmware. Have the same issue with both wired and wireless (2Ghz and 5Ghz). Changed the MTU to 1400, but still seeing sporadic connection issues.
- cowstianDec 01, 2015Aspirant
I have simmilar issues aswell. The Cabled connections seems to work fine and i do not loose the internet connection but all my Wifi units have intermittent connection. It is really ennoying. Sometimes i have to manually conntect them to the wifi again, turning off wifi and then back on. This was never a problem on my Apple Airport Extreme. Even with a range of different products from diffrent manufacturers in house.
