mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
jon-
Dec 01, 2015Aspirant
Mine has been doing this for a while. I've largely ignored it, but now all the new nexus devices run doze, the dropping seems to be stopping my 6P from going to sleep.
How does one RMA? It's under a year old, or do I just use my credit card coverage (I'm in the UK)
JamesGL
Dec 01, 2015NETGEAR Employee Retired
Hi jon,
For RMA, you may need to contact support team. Device should be within 1 year from the date of purchase depending on the region.
- willgillDec 03, 2015Aspirant
I have exactly the same issue, few times a day my x4 just drops the internet connection, it returns without fail after 1-2 minutes, very very annoying
- Rivadi_NLDec 05, 2015Tutor
I use the latest firmware 1.0.0.94 and also have these connection drops with wifi devices (tablet and phone). The wifi connection should be stable.
