mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Creakydoor
Dec 06, 2015Tutor
Any update from Netgear on this?
It seems there are dozens and dozens (if not hundreds) of people who are having the same exact class of problem.
Should we all send our routers back for RMA? Mine is less than 6 months old.
Is there some way for us to escalate this issue.
As of today, this is happening about every 10-15 minutes then I have to reset my router to get back on. This applies to wired and wireless.
Needless to say, it's just about useless and I am very much losing faith in this hardware when I can't use my desktop, laptop, tablets, phones, or XBOX.
