mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- AnonymousDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
VE6CGX
Oct 06, 2014Master
Hi,
Did you specified MAC address setting for cloning MAC on set up? If so, try default setting. My R7500 is running over a month, nothing happened to it yet.
