mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
trueshot
Oct 15, 2014Aspirant
My R7500 is working pretty well, but I might not be stressing it as much as you. Are you connected over 5Ghz? I was able to cause some sort of glitch in this router and an EX6200 extender by using extending over 5ghz with a very weak signal.
