mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
South_Park
Nov 08, 2014Tutor
Here is my update, Roku 2 is now working fine with WMM disabled on 2.4 GHz but the PS4 still shows VERY low speeds under 1 MB/s. It helps if I switch the channel from "Auto" to "11" but this is creating other compatibly problems.
A Firmware update that finally would work good would be nice.
