mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Nonlin
Dec 17, 2014Novice
So I just purchased this router yesterday. Tried searching for a match in Hero's of the Storm and it would keep disconnecting. Eventually it decided not too and I finally found a match.
Is there a fix for this. Such an expensive router only to start having troubles on day 2. :mad:
