mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
MB306
Dec 30, 2014Aspirant
Same issue here.
Changed out my modem.
Had my ISP out to check the signal.
Everything points to the router.
I am running software version V1.0.0.82
Currently have two Xboxes, three android phones, two iPhones, a printer, a Chromecast, and three windows laptops and one Macbook attached to it wirelessly. Yea, I know, too many devices, but I have a big family.
First problem I have ever had with a Netgear product.
