mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
millercentral
Jan 01, 2015Aspirant
Question for those experiencing this: Do you have IPv6 enabled?
I just got this router (upgrading from ASUS AC66U), and when I enable IPv6 I find the link to the cable modem drops after some period of time. When IPv6 is not enabled, it appears to work fine.
My ISP is Comcast in the Seattle, WA area. I have a Motorola SB6183 Cable Modem.
