mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
muetzekoeln
Jan 05, 2015Novice
Beyond wrote: Have similar issue, on the 5ghz band, any device that connects for a long period of time, (couple of hours), it becomes non responsive to the Internet. I usually have to just reconnect and it comes back alive.
That sounds like the same problem I have reported:
http://forum1.netgear.com/showthread.php?t=94334
