mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
MB306
Jan 05, 2015Aspirant
I just spoke with a Netgear representative. They called me after I set up a support ticket. My issue was diagnosed as a hardware problem. Netgear set up a RMA and will be sending me a replacement router to swap out with the router they believe has the hardware issue.
