mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
ipat
Feb 06, 2015Aspirant
Those who have problems with the R7500 using macbook air or pro try this linkhttp://osxdaily.com/2014/10/25/fix-wi-fi-problems-os-x-yosemite/
This solved my download speed and maybe other things that I am not familiar with =);)
