mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
ironpants
Mar 17, 2015Novice
I have a similar problem. My netgear r7500 keeps rebooting randomly. But the reboot does not complete. The router is always stuck with the power led being red. Disabling WMM and ip6 did help in the way that the reboots do occur less often.
