mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Puffnstuff
Mar 19, 2015Guide
After reading this thread I've discovered that I'm having a similar issue with my laptop and its intel centrino ultimate n-6300 wifi adapter. My other wireless devices seem to be ok but my laptop disconnects at random and I have to disable and then reenable the connection on my laptop in order to regain internet access. I don't know for certain that this is the same issue you are having but I've read that people with that intel adapter are having lots of issues with connectivity, however I never had it prior to obtaining this router. I've updated my drivers to the latest intel proconnectivity suite with no change in behavior. My phones never have an issue with the router just the laptop.
