mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
marcoschaap
Mar 21, 2015Novice
Puffnstuff,
I can confirm that after changing my Centrino 6300 Ultimate with a 7260 AC Dual Band module, my problems with my laptop have been solved. Now I can download files from my connected USB disk with a maximum of 455 Mbit/s :-)
