mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Puffnstuff
Mar 22, 2015Guide
I replaced the n-6300 yesterday with the 7260ac and my connection has been stable ever since. My connection speeds range between 650-780mbps so I'm happy with it. The worst part was disassembling my laptop to get to the slot.:eek:
