mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Babylon5
Mar 23, 2015NETGEAR Employee Retired
I have a 7260AC fitted, and get blistering rates, however I have noticed that it can reduce to a relative crawl at times, regardless of what network it is connected to. The answer for me is to either reboot the laptop (a bit nauseous) or disable/enable the 7260AC (very easy using F9 on my laptop). So for me the 7260 isn’t quite perfect, but is pretty close.
