mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
marcoschaap
Mar 23, 2015Novice
Babylon5 wrote: I have a 7260AC fitted, and get blistering rates, however I have noticed that it can reduce to a relative crawl at times, regardless of what network it is connected to. The answer for me is to either reboot the laptop (a bit nauseous) or disable/enable the 7260AC (very easy using F9 on my laptop). So for me the 7260 isn’t quite perfect, but is pretty close.
Babylon5,
You could try this solution from the Intel forum to rule out an issue with network scanning while connected.
1. Open Registry Editor (Windows 8/8.1, right click where Start button was, click Run, type regedit. Windows 7, click Start, click Run, type regedit)
2. Head to 'HKEY_LOCAL_MACHINE \ System\ CurrentControlSet \ Control \ Class \ {4d36e972-e325-11ce-bfc1-08002be10318} [Be sure to expand the 4d36e.... folder]
3. Inside will be a number of folders named 0000, 0001, 0002, etc. Look through all these folders until you get one that says Intel(R) Dual Band Wireless-AC 7260 in the registry.
4. Once the device has been found, search for a value called ScanWhenAssociated.
5. If you see this value, set it to 0 on hexadecimal. If you don't see the value, click edit from the top, select new, and click DWORD (32-bit) value. Rename this value to ScanWhenAssociated (exactly as shown). Make sure this value is set to 0 on hexadecimal.
6. Restart the computer. This is important. The changes won't take effect unless you do.
source: (https://communities.intel.com/thread/53294)
Hopefully this resolves the connection deterioration! :)
