mahisamk
Oct 03, 2014Initiate
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need w...
- Retired_MemberDec 25, 2014Hello,
I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
1. router to default settings
2. FW installed (76)
3. routern to default settings after upgrade
4. router reset
No problems with connection issue; stable:D
Babylon5
Mar 23, 2015NETGEAR Employee Retired
Thanks, I might give that a try, but currently the deterioration is infrequent, having said that though, it becomes noticeable when it matters i.e. I’m just kicking off a backup of a large file. So, I might just give it a go anyway and maybe I’ll never see the problem again. ;)
