DaveyG
Oct 27, 2015Guide
R7500 MU-MIMO Capability
Has the R7500 had a firmware update that allows it to utilise the MU-MIMO capability of the hardware.? If not, is this due for release soon?
JamesGL
Nov 04, 2015NETGEAR Employee Retired
Hi DaveyG,
Welcome to Community!
Are your adapters MU-MIMO capable as well? In order for the MU-MIMO to work, your adapter should support same technology.
JamesGL
Community Team
DaveyG
Nov 05, 2015Guide
I haven't got any adaptors that have MU-MIMO capability at present.
I am assuming they will gradually become available in the UK.
I noticed that the new R8500 and R7800 had this feature.
I am assuming that my R7500 has this capability and was wondering if this feature will be implemented on this router.
- JamesGLNov 05, 2015NETGEAR Employee Retired
Hi DaveyG,
R7500v2 supports MU-MIMO but not the version 1. This is the reason why version 2 was released for MU-MIMO support.
JamesGL
Community Team
- n8dawggDec 16, 2015Aspirant
Is the 7500 v2 a whole new unit or is it a firmware update?
I just bought the X4 7500. Should I return it so I can have MU-MIMO? Is there a big price difference?
- DaveyGDec 17, 2015Guide
As far as I am aware, if you have the v2 version of the R7500 you will have MIMO capability. I would have thought if you have just purchased the unit it would be v2. It may be worth checking with Netgear Support.
From what I've read it appears that the v2 has a different chipset, I believe the v1 firmware will not be updated to support MIMO capability.
I have gleaned this information from various postings so it may be wrong. Perhaps a Netgear Moderator could confirm this ?.
