justinl
Jul 08, 2017Guide
R7500 not assigning correct IP addresses to wireless clients after firmware upgrade
I just updated my Nighthawk X4 R7500 to the latest available firmware, V1.0.0.108, and wireless clients no longer receive the correct IP address assignments after they connect to the 5.0 GHz wireless...
- Sep 09, 2017
I just upgraded to the latest R7500 firmware, V1.0.0.110. This appears to have resolved the issue, although NETGEAR does not include this fix in the release notes for this firmware upgrade.
If you were affected by this issue, I recommend you install V1.0.0.110. You may need to download the firmware update directly from NETGEAR's website; when I attempted to update the firmware through the router's interface, the firmware update page refreshed constantly and indefinitely, never finding the available update.
1Nic
Aug 26, 2017Aspirant
Hi JamesGL
any other ideas on how to fix issue
or
is there new firmwre being deloped to fix issue
justinl
Sep 09, 2017Guide
- FeyroceSep 15, 2017Aspirant
Hi justinl
Just did the upgrade as well and it seems to work :-)
I'll check over the next days and see if the issues are solved!
