martinlmiller
Aug 22, 2016Aspirant
R7500 router will not commuicate with UBNT NanoStation loco with static IP address
Hi I am new to this site, and don't always understand all of the terminolgy but I would like to get to the bottom of this issue. I have been working on setting up a pair of Ubiquiti NanoStation Loc...
- Aug 23, 2016
Thank you netwrks, I believe I solved it. (well at least got it to work)
I did try to change my DHCP ranges, but with no further success. Un- reserved all IP’s. Set DHCP range from .2 – .199 . Set the static address on my radio’s to .201 and .202 and to make sure it was valid set a static IP on my printer at .219. Full unplug of LAN ports…. Powered off router and modem…… connected only the radio’s and my computer to the LAN and re- booted the modem….. waited….. and then rebooted the router. No success. (Maybe this contributed later in my set up, but not sure)
In watching the video again, I noticed that he had the IP aliasing button unchecked in his screens, but made no mention of them.
https://www.youtube.com/watch?v=hrEEOV5oA8Y
In a last ditch effort I went into my radio’s and unchecked IP aliasing.
My nighthawk router immediately picked up the AP. I can now log into the radio’s through my network and have internet in my garage
I decided to do some tests, and found that if I checked the enable WDS transparent bridge, I would lose connectivity to my radio’s through my network. As soon as I uncheck WDS again, I could hook up through my network.
Thank you for the link on IP Aliasing. It was some of the comments from people that said that they weren't sure what it does, but it seems to help to turn it off whe
Also thanks for the utube link. After hours of trying to get these to work, I cannot belive that it was as simple as that IP Aliasing check box that nobody mentioned.
I believe the issue is solved
Thank you for prompting me
netwrks
Aug 23, 2016Master
I can't see the pic yet,as it needs to be approved. Here's a link on M2 loco config . This guy is good. maybe a clue in here. Let me know how it goes.
I use UBNT routers but, unfortunately, not the loco's. Worst case, reset the 7500. Best case pick up a UBNT Edgerouter X!
https://www.youtube.com/watch?v=hrEEOV5oA8Y - M2 video.
https://www.youtube.com/watch?v=wZxJPBukjbY - threw in the M5 video by the same guy..
martinlmiller
Aug 23, 2016Aspirant
Yes, this is how I initally set these up. And then when that didn't work contacted UBNT chat. They sent this, which was a little simpler. but same result.
I just changed the DHCP adress range like you suggested from .2 - .199 and reset the radio's to .201 and .202. My priter which is set at a static .219 is visible, but not my radio's. I will have to do a re-boot tomorrow AM with just my computer attached to the router and the radio's to see if I can get them to talk.
Thank you
