dunkens
Jan 15, 2017Apprentice
r7500 slow upload speed
Hi Using a r9000 acting as a router , wired to the ap that is the r7500 placed in the second floor of the house But upload speed is crazy 1.89 Mbps Any idea how to resolve this proble...
- Jan 19, 2017
Using a cable directly to the r7500 :
Download: 394,19 Mbps
Upload : 200,22 Mbps
Using the same cable that is connected to the r7500 , but using in in the computer it gives:
Download: 430,72 Mbps
Upload: 230,45 Mbps
Length of cable , 50 meters
Connecting the r7500 directly to the fiber converter , cable length 0,5 meters
It gives the same speed as the first test posted in this thread .
So dont think its a "cable" problem , did call netgear and they put up an case on it , so i hope it goes to an RMA
JamesGL
Jan 19, 2017NETGEAR Employee Retired
Hi dunkens,
1. What is the speed of the device when connected directly to the R9000?
2. How long is the cable from the R9000 to R7500?
3. Bring the R7500 closer to R9000 and use a short cable and check the speed.
dunkens
Jan 19, 2017Apprentice
Upload: 230,45 Mbps
