DaveyG's avatar
DaveyG
Guide
Oct 22, 2015
R7500 Status Page Issue
Hi       Don't know if anyone else has noticed this. It appears that the Statistics shown for the router under Advanced -> Internet are transposed ?  (TxPkts/Tx B/s and RxPkts/Rx B/s) for WLAN a/n...
  • JamesGL's avatar
    JamesGL
    Oct 28, 2015
    Hi DaveyG,
    Perform a factory reset on the device. But before doing it make sure to save first a backup of your settings. After the reset, manually configure the router and check of you get the same status. If not, try loading the backup configuration and check if it has the same status.
    JamesGL
    Community Team
