mr_coffee
Feb 10, 2020Initiate
R7500 stopped showing up as a source on Samsung Smart TV
My Nighthawk R7500 v2 wifi router used to show up on my Sources menu on my Samsung TV so I could play videos from my usb thumb drive. Today, after working just fine for a year or more, it no longer...
- Feb 11, 2020
mr_coffee wrote:
My Nighthawk R7500 v2 wifi router used to show up on my Sources menu on my Samsung TV so I could play videos from my usb thumb drive. Today, after working just fine for a year or more, it no longer shows up.
Is your (unnamed) Samsung TV on a wired or wifi connection to the router?
mr_coffee wrote:
My BluRay disk and other wifi devices on the network are all showing up, and I can print to my network printer (wired ethernet, not off the router) just fine.
It sounds like the TV is where the trouble lies.
The usual way to troubleshoot these things is in the control panel for the TV.
michaelkenward
Feb 11, 2020Guru - Experienced User
mr_coffee
Feb 12, 2020Initiate
I redid the network configuration on my Samsung TV and it went back to showing up normally. THANKS
- michaelkenwardFeb 12, 2020Guru - Experienced User
Glad it worked out. Thanks for confirming that the traditional first way out did trick.
With luck you won't have to do it too often.
