konnexion's avatar
konnexion
R7500 stuck at network mode b/g on 2.4Ghz band
Using Wifi Explorer on the Mac I can see that my Netgear R7500 is using network Mode b/g on the 2.4Ghz band and is thus limited to a Max rate of 54Mbps - even though the Mode setting in the router co...
  • Anonymous's avatar
    Anonymous
    Dec 10, 2015
    Is WMM enabled?
