konnexion
Dec 10, 2015Aspirant
R7500 stuck at network mode b/g on 2.4Ghz band
Using Wifi Explorer on the Mac I can see that my Netgear R7500 is using network Mode b/g on the 2.4Ghz band and is thus limited to a Max rate of 54Mbps - even though the Mode setting in the router co...
- Retired_MemberDec 10, 2015
Is WMM enabled?
konnexion
Should have said, it's using WPA2
Retired_Member
Dec 10, 2015Is WMM enabled?
- konnexionDec 10, 2015Aspirant
Disabled on both bands
you might enable them seeing how it's part of the WIFI 802.11n standard
Edit I see you did. glad it worked
And voila - after enabling WMM I now see Mode a/c available and speed back up to 289 Mbps max Rate. Thanks - would never have thought of looking there !
