RoSche
May 08, 2017Aspirant
R7500: Sudden drop in 2.4 G download speed, upload is still good
Router serves both: 2.4 G and 5 G WIFI as AccessPoint. Firmware is latest. Without any changes done to the setup 2.4 G network dropped from about 25G download speed to 0.1 while upload speed rema...
- May 29, 2017
I returned the R7500 a few days to my reseller and got a R7800 instead. Could not wait any longer since I got no fix for the problem.
Everything works now as it should.
May 08, 2017Guru - Experienced User
Try manual channel 1, 6 or 11.
Try WPA2 and AES only.
Try different devices.
- RoScheMay 09, 2017Aspirant
Thanks.
WPA2 and AES always was selected.
I tried the channels you proposed, but nothing improved.
Currently i left it at ch 11 (other APs under same SSID are at ch6 and ch1). Before all were set to automatic channel selection, but spacing between them was always good.
I used 2 devices to check the speed (in addition to noting the slow speed in regular usage), both with three different software apps. Also verified at other access points that the readings make sense. Therefore I assume that there is no wrong analysis.
