RoSche
May 08, 2017Aspirant
R7500: Sudden drop in 2.4 G download speed, upload is still good
Router serves both: 2.4 G and 5 G WIFI as AccessPoint. Firmware is latest. Without any changes done to the setup 2.4 G network dropped from about 25G download speed to 0.1 while upload speed rema...
- May 29, 2017
I returned the R7500 a few days to my reseller and got a R7800 instead. Could not wait any longer since I got no fix for the problem.
Everything works now as it should.
JamesGL
May 29, 2017NETGEAR Employee Retired
Hi RoSche,
Try loading a different firmware and check if the same problem.
RoSche
May 29, 2017Aspirant
- FURRYe38May 30, 2017Guru - Experienced User
Glad the R7800 works. Take a look at OpenRouters FW for it as well. Uses same UI. What I have loaded on mine.
Enjoy.
