soyee7's avatar
soyee7
Apprentice
Sep 19, 2016
R7500 System Time Not Correct
The system time on my Netgear R7500 Router is not correct and is reading Dec 31st, 1969.  I have a static IP set using googles DNS servers, I have attempted reseting the router to the factory image, downgrading then re-upgrading to the latest firmware, several reboots, etc...  There is no NTP setting on the router itself so I am pretty much stuck with no way to correct the system time. I am trying to use the VPN on the router it is not working properly and I am betting this likely has to do with the time being off.
Any help is greatly appreciated.
Thanks,
Sasan
  • I was able to fix this on my own by doing the following.
    Who needs Netgear support when I can have free root access to the box :)  I wanted to install NTPD onto the busybox system, but I could not get he package to install. Has anyone else had experience with this?
    Good Luck!
  • Anonymous's avatar
    Anonymous
    what model modem and how is the r7500 connected to it
    • soyee7's avatar
      soyee7
      Apprentice
      It is an AT&T (PACE) 5268AC Router/Modem. The R7500 is connected to it like so:
      Internet POP (Fiber) > 5286AC WAN Port IN >  5286AC LAN Port OUT > R7500 WAN Port IN
      Funny thing is, i have a Netgear R6200 running in AP-Mode for my upstairs connected to the LAN port of the R7500 and it is able to pull the correct system time.
        Anonymous
        is pace in bridge mode if not 7500 should be in AP mode
    Good Luck!
