Bambipower
Feb 13, 2018Aspirant
R7500 v1 does it support mu-mimo?
Having the r700v1... niw i notice in the controle panel i can enable mu-mimo. Is this now working on the v1 ? Is it safe to enable it?
- Feb 26, 2018
Hi Bambipower,
We apologize for the confusion. R7500v1 does not support MU-MIMO. This will be corrected on upcoming firmware.
JamesGL
Feb 19, 2018NETGEAR Employee Retired
Hi Bambipower,
Can you provide the screenshot of the page that shows MU-MIMO feature that can be enabled?
Bambipower
Feb 20, 2018Aspirant
Yes, on the bottem
- BambipowerFeb 21, 2018Aspirant
Wil i do something wrong if i try to enable it?
- JamesGLFeb 22, 2018NETGEAR Employee Retired
Can you provide me a screenshot please.
- BambipowerFeb 23, 2018Aspirant
You can find the screensgot as an attachement in my second reply
Thanks for your help
