Tmoore1710's avatar
Feb 12, 2021
R7500v2- openvpn issue
Im looking for the beta "r7500v2-v1.0.3.11-td272-openvpn.img" firmware to fix the tun - tap issue with openvpn settings on the router.  You can use this case # 28100817 for reference. I listed the fi...
  • Tmoore1710's avatar
    Tmoore1710
    Feb 13, 2021
    Solved!!!
    I was running the latest firmware for the R7500v2. So I went back and looked at the firmwares that mentioned anything about openvpn and iOS. I found firmware 1.0.3.4 and downloaded that firmware and I instantly connected with openvpn. I later installed the newest version firmware again. Everything works.
