mark776
Jan 23, 2021Tutor
r7500v2 causing landline phone issues
My router is connected to a modem from the phone company that supplies fiber internet and phone. Our phones started dropping out like a cell phone does when it goes out of range. If I disconnect th...
- Feb 06, 2021
I have found the answer to my problem. It was easy and straitforward. I threw the nighthawk into the trash and am running on an old belkin until my new tp-link arrives. I wish to thank the community for its mature and professional responses in helping me come to my solution.
antinode
Jan 23, 2021Guru
> Not a very detialed description of that device. Maker? Model
> number?
> Unimportant, [...]
Thanks for your assessment, but it's apparently more important to me
than it is to you.
> [...] The fiber comes into the house to their modem which connects to
> the house phones for phone service and dsl for the router. [...]
That makes very little sense. It might make more sense if I knew
what your (apparently not simply a) "modem" actually was.
> Doesn't matter.
If you are so certain of what's useful information and what's not,
then you don't really need help from someone like me, who wants to know
more about your situation than "doesn't work".
mark776
Jan 23, 2021Tutor
Mr. Guru, if you do not know anything about what might be causing my problem, please do not reply. The problem is with the router. If you think the problem is with overheating, a short, bad wan port, or even firmware and can be fixed, your help would be appreciated. Please respond with pertinant and useful comments. Otherwise, your attidude and questions are showing your lack of knowledge. I am looking for someone who has had or heard of a similar problem.
Thank you.
