mark776
Jan 23, 2021Tutor
r7500v2 causing landline phone issues
My router is connected to a modem from the phone company that supplies fiber internet and phone. Our phones started dropping out like a cell phone does when it goes out of range. If I disconnect th...
- Feb 07, 2021
I have found the answer to my problem. It was easy and straitforward. I threw the nighthawk into the trash and am running on an old belkin until my new tp-link arrives. I wish to thank the community for its mature and professional responses in helping me come to my solution.
mark776
Jan 24, 2021Tutor
As a test, I attached an old router to the dsl and then plugged the nighthawk wan port into one of its lan ports. The phone problem stopped, but, even tho i'm still getting 100Mbps wireless, this is not a real solution. I don't know what kind of "static/bits?" the nighthawk could be putting out that the old router would stop that messes up the fiber modem's phone port.
- mark776Feb 07, 2021Tutor
- DGalloFeb 25, 2021Tutor
Hi mark776 , out of curiosity, what router model did you bought? Did it solved the issues you had with your r7500v2?
- mark776Feb 25, 2021Tutor
I bought a tp-link ax3000 that was on sale. Yes, it fixed the problem, but as a note, a 10+ year belkin router i had laying around also made the problem go away. I do not know what caused the problem(hardware or firmware), but i got tired of messing with it and it went into the trash. I feel the nighthawk should have had a number of years life left, but with the lack of support, it is time to try another manufacturer.
