mark776
Jan 23, 2021Tutor
r7500v2 causing landline phone issues
My router is connected to a modem from the phone company that supplies fiber internet and phone. Our phones started dropping out like a cell phone does when it goes out of range. If I disconnect th...
- Feb 06, 2021
I have found the answer to my problem. It was easy and straitforward. I threw the nighthawk into the trash and am running on an old belkin until my new tp-link arrives. I wish to thank the community for its mature and professional responses in helping me come to my solution.
DGallo
Feb 24, 2021Tutor
Hi mark776 , out of curiosity, what router model did you bought? Did it solved the issues you had with your r7500v2?
mark776
Feb 25, 2021Tutor
I bought a tp-link ax3000 that was on sale. Yes, it fixed the problem, but as a note, a 10+ year belkin router i had laying around also made the problem go away. I do not know what caused the problem(hardware or firmware), but i got tired of messing with it and it went into the trash. I feel the nighthawk should have had a number of years life left, but with the lack of support, it is time to try another manufacturer.
