mrmagloo's avatar
mrmagloo
Apprentice
Aug 10, 2018
R7500v2 Slow Since V1.0.3.36
I have Comcast 60mbps service and for the last month or so, I've been noticing only ~26mbps across ALL devices, wireless or gb wired.  At first I thought it was Comcast, and they did a bunch of tests...
  • mrmagloo's avatar
    Aug 10, 2018
    Well, to help the next guy, I just found that v1.0.3.36 turns ON the QoS, - which seems to persist even through a Restore, and the second I saw that, I knew that was probably the issue.
    The second I turned that garbage off, the speeds zoomed right back to 71mbps.
    How irritating.
